Released on September 24th 2021, the iPhone 13 mini is a smaller version of Apple's iPhone 13 and is the second mini iPhone. It features a 5.4-inch OLED, an A15 Bionic processor, and dual rear cameras.
WiFi and Bluetooth barely works - why?
9-year-old’s iPhone 13 mini. Had a very unprofessional screen + battery replacement. Now:
  • WiFi disconnects constantly (especially when gaming)
  • Bluetooth range/connection is terrible
  • Screen flickers on home screen
Already tried the usual WiFi resets, forgetting networks, etc. – no change.
Questions:
  1. On the 13 mini, are WiFi and Bluetooth handled by the same chip or antenna flex cable?
  2. Could a botched screen replacement (tons of leftover glue, possibly damaged flexes) cause both WiFi and BT issues?
  3. Any specific things to check inside?
Thanks so much!
Add a comment
Most Helpful Answer
Update your phone to it's latest software version can help you in fixing the issue.
Score 1
Add a comment
Hi @come8cmice30789
Try using the WiFi in the phone as close as possible to your home network router i.e. <15cm and check if it detects, connects and maintains a stable connection.
If it does, mostly likely it is a problem with the antenna - loose connection or faulty.
Here's a previous answer in ifixit that details how to remove/replace the antenna in the phone.
Score 1
Add a comment
Answer too:
1 I believe so
2 Most likely not, but I suppose it could
3 I would check the antenna connections, and the connections between the board/screen so you can make sure there are no shorts/kinks in the cables.
Try making sure you have nothing close that can cause interference... Hopefully this works
Add a comment
Add your answer
come8cMiceTRPr&?hqqy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 15
All Time: 53
