The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
2012 VW Passat 2.0TDI P0299 code
  • How to troubleshoot a PO299 code on a 2012 Volkswagen Passat 2.0 TDI
Add a comment
1 Answer
Most Helpful Answer
The Volkswagen Passat P0299 code indicates a turbocharger underboost condition, meaning the turbo isn't producing the expected boost pressure. This is often caused by leaks in the air intake system, such as a faulty intercooler or boost hoses, or problems with the turbo's wastegate actuator or a sticking wastegate itself. Symptoms include a loss of engine power, reduced acceleration, and the vehicle entering "limp mode".
Common causes
Boost leaks: These can occur in the air intake system, including cracks or loose connections in the boost hoses, intercooler, or the turbo-to-engine manifold.
Wastegate issues: The wastegate controls how much exhaust gas bypasses the turbo. If the wastegate is stuck open or the actuator is failing, it will cause a lack of boost.
Faulty turbocharger actuator: This is a common problem on many Volkswagen Passats, especially the TDI models, and can be caused by a failing vacuum diaphragm or leaking vacuum lines.
Other turbo issues: The turbo itself may have mechanical problems, such as a binding or worn compressor wheel, which can lead to underboost.
Intake restrictions: A very dirty air filter or a clogged intercooler can also restrict airflow enough to trigger the code.
Faulty sensors: A problem with a sensor in the boost pressure system, like a faulty MAP or boost pressure sensor, can also cause the ECU to register an underboost condition.
How to fix:
Inspect for leaks: Start with the most common and cheapest fix. Visually inspect all boost and vacuum hoses for cracks, loose connections, or signs of oil soaking.
Check the wastegate actuator: Look for any visible damage to the diaphragm or actuator rod. Use a vacuum gauge to test for proper operation, as described in the JustAnswer article.
Test the turbo: If leaks are ruled out, have a mechanic inspect the turbo itself to check for proper movement of the wastegate and compressor wheel.
Check other components: If all else fails, check the air filter, intercooler, and relevant sensors for faults.
Score 1
Add a comment
Add your answer
Exfiremek will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 35
Past 30 Days: 35
All Time: 35
