A gaming notebook, released in 2023.
No Display after switching to Ultimate with Armory Crate
Hi all, I was Switching SSD and I mistakenly switched to Ultimate in Armoury crate before nvidia drivers was fully installed, now laptop turns on window log in sound can be heard but I get no display, not even from the HDMI i guess it's stuck on display from Nvidia only but drivers are not present.
I have tried using narator to switch back but couldn't find the graphic settings anymore, tried booting from a fully functioning SSD of the same laptop with all the drivers present, still nothing.
I am thinking of removing the BIOS chip and resetting it with CH341a progrmmer. Do you guys think it will work or it's a waste of time?
NB. I've also tried to restore bios to default through f9 and f10 keys, nothing works. The screen wont display anything either from screen or HDMI
Add a comment
1 Answer
This sounds like the iGPU/dGPU mux got stuck in dGPU-only mode before drivers were installed, which can completely kill display output. Resetting BIOS with a programmer is usually unnecessary and risky. Before that, try pulling the CMOS battery, disconnect main battery, hold power 30 seconds, then reboot. Also try blind-booting into BIOS using F2/Del, or plugging in an external monitor after Windows loads. If none of that brings the iGPU back, a full EC/BIOS reset via service center is safer than flashing the chip yourself.
Add a comment
Add your answer
Ovieroghene will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 11
Past 30 Days: 11
All Time: 11
