Light control are jammed
Cannot turn on the light the controls had jammed
Your Grand i10’s light control is likely stuck because of a failed or worn combination switch, though it could also be a blown fuse or a dirty switch mechanism. Try gentle movement + contact cleaner and check the headlamp fuse. If it’s still jammed, the stalk assembly needs replacement — a quick and inexpensive repair at most workshops.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 17
All Time: 165
