Repair, disassembly, and troubleshooting information for the Steam Deck OLED, a 2023 refresh of the popular handheld gaming console made by Valve. Released on November 16, 2023. Identified by model number 1030.
Steam deck Battery Health
When I got my Steam deck about a year ago, I would get 8-9 hours in half life 2 and 2.5 hours in cyberpunk 2077, now I get around 6.5-7 hours in half life 2, and 2 hours in cyberpunk, should I replace my battery soon, or wait a bit to replace it, the system still says its at 100% percent health but I don't believe that number entirely.
2 Comments
could be dried thermal paste causing the CPU temperature to rise and requiring higher fan rpm to cool the console, drawing more power and decreasing battery life. Does your Steam deck feel hot when gaming?
by
Not really, if sits around 65-70 degrees when playing a really heavy game like cyberpunk
by
Add a comment
1 Answer
Chosen Solution
You probably shouldn't replace your battery right now. All battery age, but if there's only about an hour's difference in battery life compared to when it's new, replacing the battery now would be a waste. A new battery's both expensive and pretty hard to replace if it's your first time fixing stuff. If it works, it works. Wait until the battery life's significantly short or when it starts to bother you a lot, then replace it.
However, if you're really paranoid about battery life or feel like you'd like a few more minutes of cyberpunk, here's the guide.
Steam Deck OLED Battery Replacement
A lot of glue and fragile cables, so make sure you follow the steps carefully. It would be a good idea to read the guide before you actually start to replace it, to get a general idea of the steps.
1 Comment:
That's what I thought as well, I've repaired adhesive batteries before, but I agree that I should probably wait to replace it.
by
Add a comment
Add your answer
Caleb will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 63
Past 30 Days: 252
All Time: 3,215
