Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
Half of the keyboard lighting not working after disassembly
I replaced thermal paste on my 2020 Macbook Pro A2251. Everything seems to work fine except half of the keyboard lighting. I suspect I didn't connect the cable properly but unable to find which exactly cable. I can't find a disassembly guide for this particular model anywhere and guides for older models didn't help.
Update: Added a picture
4 Comments
Check near both the fans, I think there are 2 connections for the BL
by
Thank you very much! I'll try to reconnect this cable. Do I have to disconnect the battery just for this?
by
@ray68836 It is always recommended to disconnect the battery before any internal adjustments are made ;)
by
@livfe Thanks!
by
Add a comment
1 Answer
Chosen Solution
I am not 100% but check the connections by the fans I have marked, 2 of them should be for the BL
@danj to assist further if I got it wrong.
8 Comments:
Thanks, but mine looks totally different. I attached a picture to my original post.
by
@ray68836 Oh I took my image from the device listed guide! Edited the answer.
by
There must be a mistake. Mine is 100% A2251.
by
@ray68836 I edited the answer and marked the connections to check.
by
@livfe Thanks a lot for all your help! The longer cables (top of the image) are most likely from the fans as the fan replacement pictures for this model have them which means I need to check only the other two cables.
by
Show 3 more comments
Add a comment
Add your answer
Ray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 83
