How do you fix this error
See image content:
“Hard drive not installed” on a Dell Latitude usually means a loose or faulty SATA/SSD connection. Reseat the drive, check the flex cable, ensure it’s in the correct slot, and run Dell Diagnostics (F12). Update BIOS and try another drive if needed. Often the issue is a failing SSD or connector.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 19
All Time: 165
