Repair guides and disassembly information for the 14-inch MacBook Pro released in October of 2021, featuring Apple-designed M1 Pro and M1 Max SoCs. Model A2442.
Why is my MacBook not turning on?
Macbook not turning on. MagSafe charging LED not showing and usb c charging does not seems to work.
Left connected to dock with power delivery via usb c for 24-36 hours and when I came back it doesn't want to turn on
10 Comments:
Are you sure the charger and USB-C cable are working? Is the MagSafe connector contacts clean and the MagSafe cable is not damaged?
What is the make and model of the charger?
And lastly can you plug a USB-C power meter in line with the charger so we can see the voltages.
by
@danj
1) The USB C charger is working as it charges my samsung s24u ultra.
2) The MagSafe cable looks clean and the contacts don't seem to be damaged.
3) The charger is the NOVOO USB-C Charger 100W
4) I have not currently got a USB-C power meter, I will have a look at getting one. Is there a particular model you suggest or is any fine?
by
@danj
Thanks, I'll let you know the results as soon as I get my hands on it
by
@danj
Hi, got the results,
Top left usbc port:
5.08975V
0.01200A
0.06118W
Bottom left usb c port:
5.09750V
0.01650A
0.08411W
Right Usb c port-
no results, was just off so I assume no power
by
Show 5 more comments
Add a comment
Just give it a try, unplug all accessories and hold the power button for 10 seconds. Then, connect the MagSafe or USB-C charger directly to power (avoid dock). Try SMC reset: press Shift + Control + Option + Power for 10 seconds. Wait a minute, reconnect the charger, and attempt to power on again.
1 Comment:
@rashmimand95190
That did not work, I will be proceeding to remove the right usb c port cable from the logic board and see if that fixes it
by
Add a comment
@muhaimeenali - If you are trying to see if the port is the problem (following my last comment above) then yes you'll want to reconnect the battery with the port in question disconnected from the logic board. Placing the system on its side like an open book so the bottom is not pressed on. See if the system comes alive. If not you have a deeper logic board issue. If it does then replacing the port should get you going! Good luck.
5 Comments:
Hi @danj
The usb c port was not the issue so must be a deeper issue in the logic board like you said. I will be taking it to a reputable Mac repair shop to get it fixed.
However, I'd like to ask how much would be a rough estimate on the maximum cost of this repair.
by
@muhaimeenali - Hard to tell… it depends on what is damaged. It could be a simple capacitor or an IC is blown. If the PCB is damaged from the failure (it might be on the backside which is hidden) that could get expensive or the tech is a parts swapper not fixing boards.
by
@danj - Got the board fixed and they repair shop said they replaced 3 charge IC's, 1 audio IC as well as various caps and resistors around the IC's.
I originally used a NOVOO 100W USB C Charger to charge this device, however I have been recommended to stay away from this. I would still like to have a dock to use with my Mac and was thinking if the Kensington SD5700T would be suitable and safe to use as I would not like to do have to run into this issue again.
by
@muhaimeenali - yes sadly it can often require more than one ports repair. I just use Apples chargers so I can't offer a recommendation here on that. But I can tell you often it's not the chargers fault! The root issue is your AC power. Here the ground of the outlet/s or the main breaker panel are not corrected wired. It's also possible the buildings ground is not proper either wired or worn out. And lastly you could have a bad device leaking power to the ground service.
I recommend you get a simple go/no go outlet tester to check your outlets, or use a good meter to test the lines. Even still a surge or lightning can also damage things. I strongly recommend Good UPS for your computer gear. I have two and I even have a third to protect my TV gear.
Happy to hear your system is on the mend! Don't forget to score and accept the Answer. Thanks!
by
@danj thanks for the feedback and all you're help, I'll look into those options to save myself from any more expensive repairs 😅
by
Add a comment
Add your answer
Muhaimeen Ali will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 102
All Time: 102
