Repair and troubleshooting information for the HP Probook G6, an HP laptop part of the HP Probook series. Released in September 2017.
keyboard keys not working
Hi
Several keys of the keyboard are not working well. Some need to be clicked severall times with more pressure to work.
Can it be completely changed?
Add a comment
That is likely dirty or worn carbon contacts. They might be cleanable, but that doesn't work for long.
Best just to replace it.
Just make sure you get an exact replacement. Search for this HP ProBook 450 G5 keyboard
The service manual is here.
A disassembly is here
Add a comment
Well i will suggest you to use a external keyboard until you fix your laptop keyboard ans some time outdated driver can also cause this kind of issue as well so look for that as well.
Add a comment
Yes, the keyboard can be completely replaced. If only a few keys are faulty, try cleaning under them using compressed air or a soft brush first. If the issue persists, replacing the keyboard is the best long-term solution.
Add a comment
Add your answer
Juljan Hysenaj will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 320
