The Marshall Emberton is a portable Bluetooth speaker modeled after Marshall guitar amplifiers. The speaker only has two buttons, which are the power button and a multidirectional button for volume and navigating through tracks. Model: Emberton
Marshall Emberton Bluetooth’s Speaker Charging Issue
I have a Marshall Emberton speaker that I bought 4 years back. Now it isn’t getting charged and the customer care says that there is no repair support for this product. I’ve tried resetting the speaker, using different charging cables and chargers, etc. However nothing seems to work. When I connect it to the charger, the charging light blinks. However, no matter how long I leave it for charging, on disconnecting the charger, it only shows 2 lines of charge. And it gets discharged in no time. I think the battery needs replacement. Please confirm if anyone has had an identical or similar issue and suggest, what should be done to resolve this issue.
1 Comment
This question was migrated from https://meta.ifixit.com/Answers.
by
Add a comment
1 Answer
Most Helpful Answer
@akshayb42748 this seems to be absolutely right. It does sound like you will need a new battery. This "it only shows 2 lines of charge" means your battery does no loner accept a full charge.
Who needs "customer care" telling you "there is no repair support for this product"! you don't need that, you got iFixit on your side. To replace the battery use this guide Marshall Emberton Battery Replacement Replacement batteries are readily available at many online stores.
Let us know how it works out for you and if you need further help.
Repair is War on Entropy!
Score 1
Add a comment
Add your answer
AkshayB will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 61
