Created in 2022 as an updated version of the prior model. It has a elegant look and a performance boost than the last years Tuf Dash F15.
Wifi intel driver is down
The wifi driver in my laptop shows and error and it’s not working I tried to update it and deleted it and reinstalled it and nothing helped
2 Comments:
@laithlakmoush
what error message did you get in device manager?
what os version is your computer running? win 11?
by
@salmonjapan
Error message: Windows has stopped this device because it has reported problems (code 43)
Win 11 64-bit
by
Add a comment
Windows 11 error 43 means a device has reported a problem, often due to driver corruption, outdated drivers, or a hardware malfunction.
If you tried to update drivers via the device manager, that doesn't work very reliably.
For drivers, you might find something here https://www.catalog.update.microsoft.com... or search for "[hardware ID] drivers".
You can find the hardware ID in the Device manager.
If you find a new one delete the old one b4 you try to install the new one.
If that doesn't work, the next step would be to replace the WiFi daughter board.
Add a comment
Ah yes, the classic ‘I deleted it, reinstalled it, cursed at my laptop, and it still won’t work’ scenario.
Here’s what I’ve learned the hard way: Windows Update is usually wrong about Wi-Fi drivers. Go straight to the manufacturer’s website and get the official driver. Uninstall, reboot, install.
Also, sometimes the Wi-Fi card just wants a nap — check Power Management settings in Device Manager. After I did that, mine came back to life like nothing happened.
Add a comment
Add your answer
Laith Lakmoush will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 45
