Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
Guide for swapping logic board between XS devices?
Hey all! I have a faithful iPhone XS that I have been using as a backup phone, but recently the already-cracked back fell apart a little more, and I am worried it will only continue to get worse.
My partner also has her old iPhone XS, but it is completely dead. Suspect some sort of logic board failure. Otherwise though, it's completely intact, in fact it looks almost new! I was wondering if I could potentially take my old XS board, and swap it into her iPhone's frame. Not sure what parts would be serialized (assuming battery warning message, and Face ID would stop working at the very least), but I think it would be the best course of action as the XS still supports our eSIM setup, making it a cheap backup phone.
The only issue is, I can't seem to find any logic board swap tutorials on here! Does anybody know if the process/screws are the same as the iPhone X? I have done similar swaps in the past, so I am comfortable doing so, but I would like to at least have an iFixit guide to follow along with, as I know the screws can all be different lengths.
1 Comment
If it’s just the back glass take it to a repair shop and have it replaced.
by
Add a comment
1 Answer
Chosen Solution
Hi Sam,
Guess you could say that I'm the only reason iFixit has a motherboard guide for the iPhone X, since I wrote it.
So yes, the process for the XS is going to be very similar, but don't let the lack of iFixit guides stop you. I'll walk you through the process.
First of all, since you're going to have both phones open anyway, I'd suggest moving over all of the paired parts; it's not going to be that much extra work and afterwards everything will still be fully functional. Here's a list of the parts you'll want to move over.
  • Motherboard
  • Earpiece Speaker assembly
  • Front camera assembly
  • Battery
  • Screen
I'd suggest taking the screen from your phone so you don't lose True Tone. Another argument in favor of keeping the current screen is that you won't have to take the earpiece speaker assembly off of it; just use it all as one assembly, making your life easier.
Taking the front camera assembly means your Face ID will still work, so it's worth the extra couple of minutes to pull that assembly and swap it out as well.
The battery isn't a big deal, but I'd suggest checking the battery health (under Settings) on yours before you start. Apple recommends replacing it if it's below 85%. Even if it's close, you might want to keep it since you have no way of knowing what the battery health is on the broken phone.
Now, for guidance on this whole process, I'd suggest following the rough outline of the steps used in the iPhone X Face ID Replacement guide.
iPhone X Face ID Replacement - iFixit Repair Guide
While iFixit doesn't have everything you need for this repair, the Spanish site Nadie Me Llama Gallina does. You actually only need two of their guides to accomplish everything I've listed out. The first one is the front camera assembly guide, which requires you to remove the screen and the battery, meaning that one guide covers four of the parts you'll want to swap over.
Manuales / Apple iPhone Xs / Front cameras - Nadie Me Llama Gallina
After that, you can hop on over to the motherboard replacement guide to finish the job.
Manuales / Apple iPhone Xs / Motherboard - Nadie Me Llama Gallina
That should be all the information you need to get your phone parts swapping done. You'll want to buy a sheet or two of precut screen adhesive, and a set of battery adhesive stickers as well. If you really want to be complete, replacing the lower speaker gasket will help you keep the phone as watertight as possible. Here's a list.
Good luck with your swap; no reason it shouldn't work just the way you hope. Of course, if you're feeling ambitious, take lots of pictures as you work, and once you're done you can use those to create your very own iFixit iPhone XS Face ID Replacement guide! It's easy, fun, and you're certain to have the appreciation of the repair community and anyone who comes along after you with the same problem.
Once you're done, be sure to come on back and let us know how everything went; any learnings you come across could well help the next guy.
This custom cut adhesive film secures the front screen display assembly to the case of an iPhone XS smartphone. Models A1920, A2097, A2098, A2100. Image
Product
iPhone XS Display Assembly Adhesive
Replace the adhesive film secures the battery to the rear case compatible with the iPhone XS model A1920, A2097, A2098, A2100 smartphone. Image
Product
iPhone XS Battery Adhesive Strips
$3.99
Replace the adhesive foam gasket that fits between the loudspeaker and the speaker opening in the rear case compatible with iPhone XS. This gasket helps seal liquid and dust out of the device. Image
Product
iPhone XS Loudspeaker Adhesive Gasket
$0.99
Score 2
2 Comments:
Jerry, that's an incredibly helpful response! I will definitely check out the other site for info.
I will definitely plan on taking as many detailed photos as possible, and assuming all goes well, I will gladly do a write up for the XS! Thank you again for your guidance!
by
@sjacks1 You are very welcome, my friend. If you need help with the guide, let me know and I'll be happy to answer any questions you might have.
by
Add a comment
Add your answer
Sam will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 22
All Time: 67
