The Black+Decker LSW20 is a 20-Volt Lithium-Ion Cordless Leaf Sweeper designed for clearing debris from hard surfaces such as patios, decks, and walkways, featuring a single-speed motor with an airspeed of 120 mph and weighing 3.7 pounds.
How to remove fan blower to get to screws
How to get to the dress under the blower wheel
Add a comment
1 Answer
@daren68800
Hi,
In the video of a tear-down HERE, it looks like you just twist it to release it. There's not a guide here for this device so maybe while you work on it you can take photos and make such a guide to help other folks with the same problem? It's easy and a great way to support Right to repair and the environment!
If that doesn't help, holler and I'll try to do better for you, or if you run into problems at some point just post again with pictures to illustrate if needful (often helps) and someone will be happy to help you.
Good Luck!
Add a comment
Add your answer
Daren will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 39
