What is this problem with this lens
Name this problem or how i can fix it
Knowing exactly what model of lens you have would help. I think what's likely the case though is that some plastic tabs which are used to mount screws to and hold two sections of the lens together have probably broken off. Based on the video (and without knowing exactly which lens that is) my guess would be that the tabs that would be a part of the fixed barrel (the section of the lens which has the focus window) and the focusing unit.
All things considered, it likely wouldn't be too difficult of a repair, depending on if you have any experience working on electronics. The replacement part should be relatively cheap too. However, that assessment is just based on my best guess to what the problem is, and without a parts diagram you'd have to just open up the lens to see if that is what broke or if the issue lies elsewhere.
Based on the photo, here’s what I can tell:
The section of the zoom barrel near the gold ring appears misaligned or separated from the inner part of the lens. This is a common failure after a drop with lenses like this (especially Tamron USD and similar designs).
All of these refer to the same type of physical damage.
Inside the lens there are small plastic guide rails and screws that keep the zoom barrel in its correct track.
When the lens hits the ground, these parts can:
When that happens, the outer barrel moves freely or sits crooked — exactly like your photo suggests.
You have two options:
A lens technician can:
Typical repair cost (varies by country):
€60–€140, depending on damage.
For a Tamron-type zoom, this is the most reliable fix.
You would need to:
⚠️ Warning:
These lenses have fragile flex cables, AF motors, and precise alignment.
If forced, you can permanently damage AF or zoom movement.
Please check these quick tests:
Does the zoom ring feel loose or uneven?
Does the lens wiggle if you gently twist the front barrel?
Does it make grinding or clicking noises when zooming?
Did the problem appear immediately after a drop?
If you answer yes to any of these, it is definitely a barrel guide / internal track break.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 36
