The Kobo Nia was released on 21 July 2020. It has a 6-inch E-Ink display at 1024 x 758 pixels, with a density of 212 ppi.
Rubber Power button cover replacement
My N3060 NIA has a rubber membrane covering the power button. The membrane on my KOBO is so worn out that I have removed it. I can still turn the unit on using a tooth pic or match stick. Can I get a replacement rubber membrane/power button cover?
1 Comment:
I have this problem too, but I can no longer turn it on using a tooth pick. Can someone please post an image of what the back of the motherboard is supposed to look like?
Thanks
by
Add a comment
1 Answer
I have the same problem did you find a solution ?
1 Comment:
Still no solution except that i had the rubber cover removed and I turn it on with a wooden match stick You can see the on/off button when the rubber membrane is removed.
by
Add a comment
Add your answer
Greg in Aurora Canada will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 82
All Time: 483
