This category covers 2013, 2014, 2015, 2016, 2017 and 2018 Jeep Wrangler (JK) models. These repair guides are for a 2013-2018 Jeep Wrangler (JK) Sport, Sahara, Rubicon and Unlimited Editions.
Gear is stuck and not changing gears
Once I power on the car, all the gears : P,R,N,D is locked in the dashboard . And even if I press the brake , it's not moving
If I press the shift next to the gear I can move it to D, drive, but only the first gear is working , no 2nd and 3rd and 4th
The computer is shown an error U0404
My question is there any part in the gear shift to be replaced, or I have to replace the whole gear shift ,
Or if there is any other idea please advise
My car is jeep Wrangler 2014 , 2 door
Add a comment
1 Answer
Most Helpful Answer
@mohamadkhudair the U0404 code means "Invalid Data Received From Gear Shift Control Module 'A'. Most likely issue is the If the gear shift module. It is possible that there contacts are just gotten to dirty. You would need to open it up and try to clean the contacts etc. and see if that get's you shifting again. Take a look at this video and see if that works for you. It's the same principle as for your JK
Score 1
Add a comment
Add your answer
Mohamad Khudair will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 53
