My computer is black screen and won’t turn on!
Hi, my HP EF model laptop went black screen and won’t turn on. Everytime I press the turn on button it flashes once white on the side by the usb ports, the small led light to the side of them. I hooked it up to a monitor with the usb to see if it was the display, but it didn’t work. Also it doesn’t turn on at all with no fan sound running. I tried to check the battery, where you take it out and press the turn on button then put it back, but no good news there. I also got a brand new charger to see if it was the charging port, but all it did was charge my battery back to full/white light. If anyone could help it would be appreciated, I was thinking it is the ram/motherboard, but I’m not sure.
1 Comment
Hi @hoodie78076
What is the model number of the laptop as shown on the product information label on the bottom of the laptop?
by
Add a comment
1 Answer
Chosen Solution
Your issue sounds like a hardware fault since there’s no fan spin or display. First, try a hard reset: disconnect the charger, remove the battery (if possible), press and hold the power button for 30–60 seconds, then reconnect and try powering on. If still dead, reseat or swap the RAM sticks—faulty RAM often causes black screen/no boot. Also, remove any connected devices (USB, external drives). If there’s no response even after these steps, it’s likely a motherboard or power circuit failure. At that point, professional repair is recommended, as replacement parts or board-level work may be needed.
1 Comment:
Hi thank you so much! I ordered a new ram for replacement and it worked! Thanks so much for the information!
by
Add a comment
Add your answer
Hoodie will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 59
