The Chevrolet Blazer (4WD model T-10) and its rebadged variant, the GMC S-15 Jimmy (4WD model T-15), are compact/mid-size SUVs manufactured and marketed by Chevrolet and GMC from 1982-2005 across two generations.
Engine stall and rough idle after cap and rotors replacement
Cap and rotor replace and tune
Add a comment
1 Answer
Chosen Solution
My most infamous repair blunder came when I had similar symptoms after a cap and rotor replacement.
After a couple of days troubleshooting, I finally realized I had switched two of the spark plug wires. Once I finished banging my head on the worktable, I swapped them back and everything was fine.
So get yourself a cylinder diagram and the firing order and triple check the plug wires go to the right plug.
Score 1
1 Comment:
Thanks Jerry....I thought about that but haven't done anything from banging my head too lol.... I'll definitely check it though.... thanks again man!
by
Add a comment
Add your answer
Lowride92 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 42
