My tv keeps going on and off
Ok so I turned my tv on today and it won’t go to the home Roku screeen instead it flashed on to the hi sence Roku tv screen then turns off then turns back on then turns off over and over again
@akl27873 if it turns on and off consecutively and you can verify that it turns off with the power LED (Power LED turns on and off the same way), then it is the power board. If it is just your picture that turns on and off (power LED stays on the whole time) it is your backlights that have failed. That is a common issue with Hisense TV's.
My TV is doing the same thing, however, I can periodically watch it. The problem that I experience only happens after several minutes of watching it. Then it will go off. If you turn it back on sometimes it will load to the home screen, sometimes it will just turn back off. I believe that it is either overheating or the power supply is faulty since I can watch TV for a short period of time. The power LED on my TV goes off when the TV comes on and is lit when the TV goes off or returns to standby.
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 49
All Time: 293
