The ZCT1 Controller varies by Generations, this is Gen 3 out of 6 AKA the JDM-020.
Joystick drift when using L joystick
MY left joystick resist going to the left, afterwards it drifts to the right
Score 1
Add a comment
To address your left joystick's resistance to the left and subsequent rightward drift, you should first try to clean the joystick with compressed air or a small brush to dislodge any debris, then update your controller's firmware. If these don't work, the problem is likely caused by internal wear on the potentiometers, which may require internal cleaning, replacing the thumbstick module, or professional repair.
Personal email address removed to avoid solicitating business
Add a comment
Replace both left and right potentiometers with hall effect ones.
Add a comment
Add your answer
gianclifford Ozarraga will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 26
Past 30 Days: 82
All Time: 212
