A Desktop PC built from off-the-shelf DIY parts, rather than a prebuilt from a major manufacturer. These can also be built by a system integrator using off-the-shelf parts.
bluescreen of memory management
my pc gets memory management error out of nowhere and reboots several times when i open many apps or gets booted bhen playing games or doing any of the work
Score 1
Add a comment
1 Answer
Most Helpful Answer
  1. Check memory seating inside PC , in the slots
  2. Run ram check
  3. Test with diffrent good known ram & re-run ram check (if bad > )
  4. clean slot or cpu pins
  5. If it works with new ram , clean the old ram golden pins with eraser &/or contact cleaner + a brush
  6. Re-test.
  7. Update bios , set manually ram timings & voltage to ram maker specs ,
  8. Check motherboard compatibility with problematic ram on mb maker home-page. (if it's not in the QVL list it may not work properly so test your ram on diffrent system.)
Score 1
Add a comment
Add your answer
Yasir Arfat will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 156
