Help me I Have a printer problem
The Paper is getting stuck or something pls help me and i am not able get any print seens like 5 MONETS
If you sure it's paper error, you must change the paper roller or check the paper switches and sensors for a dirt. The problem in the paper section is common on the printers.
@kapitalizm - We do want people to help others, but one needs to be careful on what they post. Sending people on a wild goose chase is not helpful.
Printers often jam up due to paper dust making the feed rollers slick so the paper is not feed in correctly. Cleaning the dust out using compressed air and then wiping down the feed rollers with reagent grade ~80% isopropyl alcohol. Then there's the sensors which can be optical or mechanical that may need cleaning. HP has published most of their printers service manuals, as such its best to aim people to the HP site HP Designjet Printers - Printer Manuals, Operator's Manuals, User's Guides
How about re-writing your answer with these.
Take some time to look how others answer questions which have a high Rep score. Try to stick with an area you know well and if you venture out do the research like what I just gave you.
@danj That's good, but I'm trying to be short, and send people NOT to do what they don't have to. I'm not sending people to replace the LCD module if they USB connector is broken.
Also I don't have to teach people about how to solder or search for a broken semiconductors on the if the original question was "Idk what to do" from people who seems don't familiar with repair technologies. Because there's a many another guides how to do it and we don't have to repeat them.
Some bunch of the question authors don't reading the answers at all, so if there's a feedback and dialog from question author, I'm ready to give much detailed instructions.
I ask for your understanding.
@danj That actually means, "change the roller" is enough to search for a guides like "how to change a roller". If someone will ask me about my vision on how to do it, I'll tell my vision or just say "I don't know".
@kapitalizm - This is a paper issue within a printer, how does a LCD get into the conversation here or even changing a roller?
You're missing the point! Stay focus on the Q!
One does not need to replace any parts, only clean, compressed air to blow the dust out and then clean the rubber rollers with isopropyl alcohol as I explained. Look through the older Q's you'll see that's all that's needed unless the mechanicals has an issue.
@danj I missed the mark on this thinking it was a software errror, but cleaning sheets can also help.
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 34
All Time: 873
3 Comments
I have this same issue on my smart tank 450 seems to be getting stuck at a metal plate in the back of the printer and used my air compressor and had some stuff come out but i just discovered there is a flap on the bottom of the printer, undo the clips on it and it opens up and it lets out some stuff that’s stuck in it try that and see if it helps
by Chay Foale
My printer does no give me print but printer take page . When if printer take page and print out the colour is pink and white
by kartik shaishav
If it's print in pink colour, clean a the printheads if it's not working then replace it .👍
by Abhimanyu Rastogi
