Why is my laptop not turning on?
Laptop Model: HP EliteBook 840 G3 (Energy Star)
OS: Windows 10
SSD: 256GB NVMe
RAM: 16GB
Issue Summary
After a recent Windows 10 update (auto-installed overnight on 10/09/2025), my laptop no longer boots properly.
When I press the power button:
- Power button, keyboard backlight, and Caps Lock light all turn on.
- The HP logo briefly appears on screen.
- After that, the laptop powers off by itself.
- This repeats in a power-on / power-off loop.
Troubleshooting Attempts
- Power drain reset – Held the power button for 30 seconds to discharge. No change.
- Battery removed – Tried running only on the adapter cable. Result:
- Power and Caps Lock blink once, then system shuts off, looping again.
- CMOS reset – Removed and reinserted the CMOS battery. No effect.
- RAM reseating – Swapped RAM modules into different ports. Problem persists.
- BIOS recovery attempt – I already have the correct BIOS flashed onto a USB drive, but the system doesn’t stay on long enough to start recovery due to the boot loop.
- Pending test – Planning to test with a different RAM stick to rule out memory failure.
Current Situation
- Laptop is stuck in a boot loop, unable to load BIOS recovery or Windows.
- Only remaining suspected causes: RAM issue, motherboard fault, or BIOS corruption.
Anyone with the same issue and successfully fixed theirs?
