Repair information for the Audio Technica ATH-M20X headphones. Identified by model number AUD ATHM20X
How do I open?
I have a pair of these headphones and something is rattling inside. Can I open these and get it out, or are they factory sealed? If I can open them, then how? thanks
Score 1
Add a comment
1 Answer
Yes, you can open them. You will need a Phillips #0 screwdriver to get them open, and a plastic card or flexible pick (or even a crochet hook) to get them back together. There are 2 screws on each side clamp (the parts labelled L and R), and three or four on each ear (under the ear cushions, which you can pull off by hand without damaging them). I would check the ears first for the rattling as there is more room inside them than anywhere else on the headphones. The procedure for getting the ear cushions back on requires a bit of patience - tell me if you find you need a video to demonstrate :)
Add a comment
Add your answer
Storm will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 43
All Time: 313
