Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
My iPod Touch volume/power cable broke.
Now my iPod touch won't show anything. I know it's on because when I hold the home button the voice assistant talks. I did see a white screen once. Also my computer detects it. I can't do any reset because my flex cable for the volume/power is ripped. But i'm also not sure a hard reset would work. Did this happen to anyone similar? Did you fix it? How?
Add a comment
Chosen Solution
Hate to say this, Justin, but when you replaced the lcd and pulled up the logic board you probably ripped the power/volume flex cable. To repair your iPod, is going to involve desoldering the hot terminal off the battery, pulling the logic board, and soldering in a new flex cable. And if you don't have the right equipment and experience you'll dig yourself deeper into a hole that can include lifting solder pads, solder splash, tearing other cables etc. At this point I suggest you send your iPod off to a business that specializes in iPod repairs.
Score 1
Add a comment
It sounds like the front panel display went out. I would try replacing it.
Add a comment
I'm having exactly the same problem. How did you fix it?
Add a comment
Add your answer
Justin Narvaez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 9
All Time: 1,088
