Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
Why is there water on the bottom of the refrigerator?
Water is pools up under the vegetable and fruit bins?
Add a comment
Theres a clog in the condenser drainage line. Causing the water to back up and leak. Clean the line to unclog and clean remaining water. Sometimes if the freezer freezes up, it'll need to defrost. Which would also result in water under the fridge. I'd definitely would check line first.
Add a comment
It is usually caused by a clogged defrost drain or a leaky door seal that lets in humid air. A blocked drain prevents condensation from draining and evaporating, leading to water pooling inside the fridge. A damaged door seal can also cause excess moisture to condense and collect as water. Other possible causes include a cracked drain pan, a water line leak, or incorrect temperature settings.
Add a comment
Add your answer
Alfie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 44
