The Nissan Sunny is an automobile built by the Japanese automaker Nissan from 1966 to 2006. In the early 1980s, the brand changed from Datsun to Nissan in line with other models by the company. Although production of the Sunny in Japan ended in 2006, the name remains in use in China and GCC countries for a rebadged version of the Nissan Almera.
Why is engine misfiring
Why my engine misfiring
Add a comment
It could be worn spark plugs or bad ignition coil or bad fuel injectors/wiring to injector. I suggest that you take it to a mechanic to do a proper diagnosis and plug it into a code reader.
Add a comment
Id change the spark plugs and spark plug wires, if persists coil packs...
Add a comment
Add your answer
TAFADZWA Mutsinze will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 142
