The ZOYI ZT-703S integrates the functionality of an oscilloscope, a signal generator, and a multimeter, providing a multifaceted tool for diverse applications.
Multimeter function is not working
Hello. I have a ZT-703S with a problem: the oscilloscope function works fine, all buttons work, and it takes measurements normally. However, when I switch to the multimeter function, only a few windows appear, including the analog scale, but no numbers appear. It no longer responds to functions like diode, resistance, and voltage. I updated the firmware and reset the settings to factory settings, but it still hasn't returned to normal. Does anyone know how to fix this?
4 Comments:
Hi @brunogouve48763
had you checked the internal fuse?
by
Yes, I checked the fuses, they are ok. I haven't found the solution yet.
by
Isn't the issue in below Youtube video a similar issue as what you have?
https://www.youtube.com/watch?v=P6QntvNA...
He was a able to fix it by re-soldering the chip.
by
Hello!
Yes, the same problem as in the video.
However, I resoldered the component as instructed in the video, and it didn't work. When measuring with an oscilloscope, there are frequencies in the transformer's primary and secondary. But it still doesn't work.
by
Add a comment
1 Answer
Ah OK, sorry to hear it didn't work for you.
Sorry that I can't be of more help.
Hopefully there are others who can.
Good luck!
Add a comment
Add your answer
Bruno Gouvea de Paula will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 52
All Time: 485
