How to fix PS4 dualshock controller right joystick stick drift
The right stick when pressed down just moves the camera up when pressed to slide in a game like Fortnite and when aiming it's not stable and moves by itself in any direction so I constantly have to pull it back to track a player in a game
Score 2
Add a comment
Most Helpful Answer
The Dualshock 4 controller uses potentiometers for sensing joystick positions. Since these are mechanical sensors, they wear down over time, usually within a year or two depending on usage.
Sometimes you're lucky and there's just some dust inside the potentiometer that you can remove with a blower, most more often than not you will have to purchase either a replacement joystick assembly, or new potentiometers, and perform some soldering in order to fix stick drift on these controllers.
Score 1
Add a comment
The controller didn't charge and then stopped working.
Add a comment
Add your answer
Tshepang will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 120
All Time: 962
