Why it won’t tuen on
Ps5 only gives 1 single beep no light no fan no nothing how can I check and fix because I believe it’s the mother borad or power supply
Hi!
It does sound like a motherboard issue.
What you can do is to measure the power supply. It should give 12V also in stand-by mode. If you are unable to test it, please try with a new power supply, just to rule it out.
If the same issue is happening, then you might want to check the motherboard for shorts.
Please let me know if you need any guides!
it does get 12v power but no 3v or 5v stand by power.
Did you test with a new power supply? Would try that first to rule it out. Just to be sure.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 62
