The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 Questions View all
2 solid red rings, heat sinks not heating up
I received anXbox 360 that had the x clamp fix and the penny trick done to it. When I plug the power supply into the Xbox it automatically shows two solid red lights on 2nd and fourth quadrant if the Xbox is lying flat... Sometimes when I unplug the power supply from the back of the Xbox and then plug it back in... It will show 1 solid green light in the second quadrant and 1 solid red light in the 4th quadrant... Or sometimes it will show 1 solid red light in the fourth quadrant... Every post I've seen is about flashing lights... Well, these lights don't flash... It won't even let me do the secondary error code.... When I hit the sync and ejector button the light or lights stay solid red... Can someone please help
Score -1
Add a comment
1 Answer
Chosen Solution
First, tear the xbox down to the board. Then take the CPU and GPU heat sinks off and clean them. Make sure to reapply thermal paste! Guides are below.
Guide for tear down: Xbox 360 GPU Heat Sink Replacement
Guide for cleaning: http://www.youtube.com/watch?v=qKa9emgpL...
Next, reflow the RAM chips on the board of the 360. A re-flow can be done a number of ways. depending on the tools you have on hand will depend on which method you want to use.
Guide for reflow: Reflowing Xbox 360 Motherboard
I had a very similar problem and this worked for me!
Cheers
Xbox 360 GPU Heat Sink Image
Guide
Difficulty:
Difficult
1 - 3 hours
Xbox 360 Image
Guide
Difficulty:
Difficult
1 - 3 hours
Add a comment
Add your answer
Scott will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 887
