The HP EliteBook 800 series includes display sizes that range from 12.5 to 16 inches, supporting refresh rates up to 120 Hz. Processor options include the Intel Core i5/i7, 13th/14th Gen or the AMD Ryzen 5/7 7000 Series. Certain configurations also may support up to 64 GB of memory and up to a 2 TB SSD.
How to Replace keyboard
My laptop Doesn't work,but why
Score 1
Add a comment
1 Answer
Most Helpful Answer
Depends on the generation. G6 and under are modular but the G7 and later models build it into the palmtest where you replace both :-(. That said it isn't hard to find them but they can be pricey. What you can often do is find good used ones with no wear on them due to issues like persistent MDM bricking motherboards so they usually end up being ~$50-60 for good low use upper cases.
Take the model and search on eBay for a palmrest assembly if it's a G7 or newer, or if it's the G6 and older the keyboard has a sticker on the back. That's your reference.
Score 3
Add a comment
Add your answer
SHAKIB KHAN will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 16
All Time: 211
