Cellular reception has weakened after I replaced the battery
Replacing the battery, I struggled to separate the screen from the body, but eventually managed by using a boxcutter to start the separation by inserting it near the lower right of the body, and then I used the plastic plectrums to go round the body. I fear that by scratching the inside of the body, I have weakened the cellular reception, is that a possibility?
2 Comments:
Could you have damaged the cellular antennas? They are along the inside of the frame.
by
Thanks for replying Andrew, do the cellular antennas run along the opposite side to where the ribbon connectors are? If so then you are right, and I wonder if the antennas are easily replaceable?
by
Add a comment
