Repair, disassembly, and troubleshooting information for the iPhone 15, released September 22nd, 2023. It features a 6.1" OLED display, a 48 MP dual-camera system, and USB-C.
Panic string from iPhone 15
*- "panicString" : "panic(cpu 1 caller 0xfffffff04695f930): SMC PANIC -
ASSERT: targetVd37Vtarget.cpp:258: 0, SMC BSC failure, spreadsheet
ver(*10) 40|nS.sensor array 0 - 4 is Oxa1, 0x0, Ox0, Ox0, Ox0 InF.sensor
array 0 is 0x0|n|n - Misc(2) OUTBOX1 not ready|nASSERT: targetV/d37V
target.cpp:258: 0, SMC BSC failure, spreadsheet ver(*10) 40|nS.sensor
array 0 - 4 is Oxa1, Ox0, 0x0, Ox0, Ox0 InF.sensor array 0 is OxO|n|n|nRTKit:
RTKit-2784.122.1.release - Client:
AppleSMCFirmware_H15-5204.122.2.d37.REL|n!UUID:
be2d7910-6e55-3274-9ff4-621de3df0807\nASLR slide:
0x0000000000000000|nTime: 0x0000000108432b81\n|nFaulting task 2
Call Stack: 0x000000000004f184 0x000000000004eb3c
0x000000000004e958 0x000000000004d334 0x000000000003b698
0x0000000000042de4 0x000000000004acf0|n|nChinook ASC Async
error info: Inl2c_err_sts 0x5000fbfc00000000, I2c_err_adr 000000000000000000, I2c_err_inf 000000000000000000|nlsu_err_sts
000000000000000000, fed_err_sts 000000000000000000, mmu_err_sts
000000000000000000|ndpc_err_sts 000000000000000000|n|nMailbox
(0): (0)|n Inbox AKF_KIC_INBOX_CTRL = 0x00020001,
AKF_KIC_MAILBOX_SET = 0x11111101|n Outbox AKF_AP_OUTBOX_CTRL =
0x00020001, AKF_AP_MAILBOX_SET = 0x00000000|n|n dir endpoint
timestamp
msg\n
ミニニニニニ
ニニニニニニニニニニニニニニニニニ=/n
ーニニニニニニ
0x424444310000e013\n
[RX]
user01 0x0000000106025ef0
Score 1
1 Comment
help please for solve these problem
by
Add a comment
Chosen Solution
Charging port problem. The smc is not detecting the charge port assembly as it should. Try a new one but make sure its a real one and not a aftermarket so all the components are on it. Some aftermarket have bits missing making the problem worse.
1 Comment:
try it but not solved i think it is from mother board
by
Add a comment
Most Helpful Answer
iFixit has a wiki page dedicated to the particular kind of panic your first log indicated.
iPhone SMC Panic Assertion Failed - iFixit
According to that log, you're seeing a battery problem.
iPhone Model
iPhone 15 Pro and Pro Max
Sensor Array
0xa1
Likely Issue
Battery
Replacing the battery should clear up that problem, although it's always possible it could be a connector or motherboard issue, but a new battery is definitely the place to start. I don't know where @nige56 got their information, but your panic log is NOT showing a problem with the charging port.
You cut off the first part of the log so I can't verify the model information, but this is showing the panic is specific to a 15 Pro or Pro Max, not a plain 15. Check the Product field of the panic log for an exact model number.
Speaking of product numbers, your second panic log appears to be for an iPhone SE 2020; if that's the case I strongly suggest you start a new question for that one, as it's a completely different issue.
Please don't "accept" an answer if your question hasn't been answered sufficiently. When you do that, people assume your problem has been solved and will tend to ignore your question in favor of ones that don't have an answer.
Score 1
Add a comment
{"bug_type":"210", "timestamp":"2025-09-01 18:25:11.00
+0530", "os_version":"¡Phone OS 18.5
(22F76)" "roots_installed":0, "incident_id": "D52CC646-01C4-419C-9D3
"build" : "iPhone OS 18.5 (22F76)"
"product" : "iPhone12,8",
"socid" : "8030"
"socRevision" : "11"
"incident" : "D52CC646-01C4-419C-9D30-E1CBC5005B7A",
"crashReporterKey" :
"4с6445658c8511d1909095d9e5b16c04676434f4",
"kernel" : "Darwin Kernel Version 24.5.0: Tue Apr 22 20:36:50 PDT
2025; root:xnu-11417.122.4~1VRELEASE_ARM64_T8030",
"date" : "2025-09-01 18:25:11.78 +0530",
"panicString" : "Unexpected SoC (system) watchdog reset occurr after iBoot panic save storage init"
"panicFlags" : "Ox0"
"codeSigningMonitor" : 1,
"bug_type" : "210"
"foregroundAppHash" : "2039050713",
"repairStatus" : "3",
"binaryimages" : [],
"notes" : ["iBoot panic-save unexpected reset, boot faults: rst wdog, reset_in_1", "missing stackshot buffer or size"]
Add a comment
Add your answer
Saini Mobile Wizards will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 25
Past 30 Days: 233
All Time: 2,520
