Suddenly battery problem on Dyson v15
Hi,
I have a Dyson v15 detect and it worked great within the warranty. But few month later it just turns off and did not start again. No LED function in battery, not in starting, not on loading. I measured the small connectors from the battery itself and getting 24v. The bigger connectors do not have any voltage, when pressing spring loaded plastic pin and also when not. So for me it looks like a defect battery. I ordered some spare part from AliExpress which i am able to load and when i Insert it, the display turns on, but i cannot start the machine.
So i measured the voltage on that alternative battery and it is 28V on small pins and 12v when spring pin pressed. On big connectors I get ~0.24v. when pressing the spring pin it changes, sometimes to 28.5V, sometimes it is just struggling and went back to 0.24v.
I don't know the expected behavior. Have someone here a working original battery and can measure the voltages? Between the small and big connectors with and without pressed spring pin.
I tried to film it. For me the reactions of the battery for pressing the Pin are stupid. Is my alternative battery also defect?
Add a comment
1 Answer
The battery has a fairly smart BMS board. When the pin is depressed, it likely intentionally disconnects the main power rails while the Cricut checks to an analog front end for the microcontroller to check for fault states like over-discharge, low voltage, overcharge, high voltage, short circuit, cell SOC balance, and operating temperature. This is a safety feature and an expected behavior. The battery that doesn't restore itself to operating voltage likely failed the battery health check for one reason or another.
I'd check the cell balance and cell resistance individually I'd you are knowledgeable and can do so safely.
I'd also measure the BMS's temperature sensor in resistance mode on your multimeter, and check that the value is close to 10k ohms
Check the handle's battery terminals for a short circuit
Ensure the power switch electrically closes.
Clean or replace all filters and empty the dust bin
Open the vacuum and ensure the blower motor isn't stuck and there is no debris lodged inside.
MyCheck recommendation is to replace the battery pack with an OEM one.
I would not trust an AliExpress power tool battery to work properly for something as finicky and proprietary as a Dyson hand vac.
Please always follow safety guidelines for handling lithium-ion batteries and disposing of them properly.
Add a comment
Add your answer
Albert Onestone will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 62
Past 30 Days: 328
All Time: 1,017
