The Honda GX200UT2 is an air-cooled 4-stroke overhead-valve, 196 cc, 5.5-horsepower engine. This diagram supports sub-models: HT2, HTC2
engine wont turn on
whenever i try to turn on engine it sputters a little but never starts
Add a comment
If it is a gasoline engine, and the gas is not fresh, that could be it. Buy starter fluid, spray into carburetor, air intake or muffler, if it starts for a second, then it is bad/old gas. Drain the tank and carburetor, add fresh gas.
Is switch "on"? Honda has a switch.
Add a comment
@aisanboy27 this " sputters a little but never start" sounds like a fuel issue. Either you are not getting enough fuel or not enough air. Remove the spark plugs Look sat the face of the plug since it will tell you story. Depending on the face of the sparkplug, you will know how the engine runs (or why it may not). Remove the air filter and check the choke and the linkage. Check the fuel tank and the fuel hoses. Make sure that you are getting fuel to the carburetor. If all of those things are a-okay, then try to start the engine and squirt some fuel (or starting fluid) into the carb. If the engine runs but sputters and chokes again, check the fuel bowl on the bottom of your carb. There will be float that opens and closes a needle valve which lets fuel into the carb. If the float is stuck or the needle valve is stuck, your engine does not get any fuel. Reseat the needle valve and ensure proper float operation.
Let us know what you find out. If in doubt, you can always post images with your question for clarification Adding images to an existing question You will also find the service manual for this engine on this page Honda General Purpose Engine GX200UT2 under the Document heading. It'll help you with the tasks described and should also help further troubleshooting if necessary.
Add a comment
Add your answer
Aisan_boy27 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 177
