Repair and disassembly information for the fifth-generation 12.9" iPad Pro featuring Apple's M1 SoC and an XDR mini-LED display. Released May 2021.
Display issues 4th gen 5th gen
I have 2 x 12.9’s with the same issue one hasn’t had anything done to it the other had a new screen assembly installed.
Issue is the display is very faint can only see with a light on it. Tried all the typical solutions to no avail, decided to replace the screen assembly put the iPad on the heat mat to remove the screen and the screen comes back to life, I get the “too hot” first when it cools down it’s fine and works normally, few days later same problem, heat up the iPad and it works again for a few days etc…was going to fully replace the screen assembly but now I also have a 5th gen 12.9 with the same issue but the screen was replace A few weeks ago!
Any ideas
Cheers
Score 2
Add a comment
1 Answer
Most Helpful Answer
The display issue on 4th and 5th gen iPad Pro 12.9" models can be caused by cold solder joints or microfractures, defective display flex cables or connectors, LCD panel issues, or logic board problems. Heating the device temporarily brings the display back to life, but once it cools, the problem returns. To fix the issue, check and reseat display connectors, inspect for cracked solder joints, try a known-good screen assembly, or consider a professional board repair.
Score 1
Add a comment
Add your answer
Iphoneman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 40
All Time: 449
