Dryer doesn't turn on, periodic clicking from panel after power outage
After a brief power outage, our dryer doesn't function at all (panel is unresponsive, no lights, etc.). There is just a periodic clicking noise coming from the beep speaker on the circuit board. Before the power outage, the dial had been left in an on position, and so I suspect a power surge to the board when the power returned.
I've ruled out an issue with the receptacle and thermal fuse. Power is clearly getting to the board. Inspecting the motor, I don't seem to see a belt switch to test, so I don't believe this model has one. Is there anything else I should assess? Can I somewhat safely assume the issue is with the circuit board?
