The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
What is causing water to drip slowly when cycle is finished
Water slowly drips into the barrel when the cycle is finished. even after turning off both cold and hot water inlets ..still drips. has not changed the problem
Add a comment
1 Answer
@marlenepor13769 sounds like you got two leaks. One on your water faucet where you hopefully connect the water supply hose for the washer. The other leak is your water inlet valve. I would start by replacing the water inlet valve.
To help you with that we will need to know the exact model number. 110 is a series that has a multitude of washers.
Add a comment
Add your answer
Marlene Porter-Blair will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 40
