The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Nintendo switch dock light is blinking
My Nintendo Switch is plugged into my dock and the light is blinking. And the switch wont turn on.
Add a comment
1 Answer
Most Helpful Answer
Hi Julian!
Basically the dock is having issues at the moment to be connected with your Switch.
Make sure you have the original Nintendo charger connected to the docking station.
If this is the case, disconnect everything from the dock and wait for 2 minutes. Then reconnect and try again.
If the issue stays, then try another dock (if possible) and check if the issues are solved.
Otherwise you could replace the dock it's mainboard to solve it.
Part: 1PCS Original Motherboard Dock Repairing Charging Board for Nintendo Switch / OLED HDMI-compatible TV Base Circuit PCB Mainboard - AliExpress 44 (those are not that expensive).
Please let us know how it goes!
Score 1
Add a comment
Add your answer
Julian Schwartz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 104
