Right Joy Con will charge but not connect to switch.
I am currently setting up a used switch that won't connect to the right Joy Con when clicking in. I've been able to RCM successfully, so I know that some of the contacts on the rail work. I have used isopropyl alcohol on the ribbon cable contact, the pins at the bottom of the rail, and over the general rail to clean. The ribbon cable shows no abnormal bends, and all the contacts that are visible seem clean and intact. This is a new OEM Joy Con that it's being attached to, and the Joy Con charges when it's connected to the rail.
Since this is a new (to me) switch that I am setting up, I cannot go past the intro scene where it requires me to click in both Joy Cons to the unit (that eliminates the possibility of just using Bluetooth).
What else should I try now?
