Shop the Holiday Gift Guide
Acer TravelMate is a line of business-oriented laptops introduced in 1997. The TravelMate B115 was introduced in 2014.
Device ran into problem
Everytime I try to turn on my laptop, it's Acer TravelMate B117 by the way. But when ever I try to turn it on, I get a blue screening saying something like "device ran into a problem :(" and then it asks me to restart, when I click restart it just goes into alot of loading screens and goes back to the same screen that says " device ran into a problem:("
Add a comment
1 Answer
Hi @abdelabdramane
If Win10 is installed in the laptop try the following and check if it resolves the problem.
Turn on the laptop and when it boots into Windows, press and hold the Power button operated until the laptop shuts down.
Do this 3 times in a row i.e. Start >boot > force stop >start > boot > force stop > start > boot > force stop etc.
On the 3rd attempt it should boot int the Windows Recovery Environment menus.
If it does when in the WRE menus, select Troubleshooting > Advanced > Startup repair and follow the prompts.
If it doesn't get into the WRE menus, create a Windows recovery USB disc. You can create the recovery disc from any known working Win10 PC. All you need is a 16GB USB flashdrive and 1-2 hours of time. In the host PC go to Control panel > Recovery > Create a recovery disc and follow the prompts.
Once you have the USB recovery drive, insert it into the laptop and start the laptop and then quickly press F12 and change the boot order to USB as the 1st boot option.
The laptop should boot from the USB drive into the WRE menus. Follow the procedure as outlined above.
Add a comment
Add your answer
Abdel Abdramane will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 32
All Time: 293
