The DeWalt DWD450 is a corded 1/2" 11 amp right angle drill.
How do I wire up the vsr trigger switch
I have a new switch I need to install on the drill bit don't know how to wire it
A
Add a comment
1 Answer
Most Helpful Answer
I don't know if wiring diagrams are available for your drill, but generally my process is to open the drill up to get to the switch, then use the existing switch as a guide to where each wire goes. Take one wire at a time and move it from the original switch to the corresponding point on the replacement part. Is there a reason that won't work for you?
Score 1
2 Comments:
To much time between new switch arriving. Took old switch out to get part number and. Don’t remember sequence to put back
by
@tony20811 How many wires go to the switch?
by
Add a comment
Add your answer
Matt Littlejohn will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 77
