Up to 20% off select tools
The 8th generation Honda Accord
A/C Climate Control Switch Problem
A/C selector switch on climate control will not cycle on compressor and indicator light on switch does not come on. I saw where someone posted a troubleshooting procedure link but not for a 2012. Thank you.
1 Comment:
@bigfishtanner you've checked the instructions for the 2010 on here? The 2012 should be pretty much be identical. What differences have you noticed?
by Share
Add a comment
1 Answer
Most likely switch is failed internally if the indicator light wont come on, but its also possible theres a fault in the wiring harness
Add a comment
Add your answer
BigFish Tanner will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 294
