Repair information and disassembly guides for miscellaneous computer hardware devices.
How to fix adapter
How to fix adapter
Score -1
3 Comments:
Hi @sabahemmanuel
More information is needed to help you.
What kind of adapter i.e. power adapter, cable adapter etc?
What is the problem with the adapter?
Post an image of the adapter in your question showing what the problem is if it is a physical problem i.e. broken. Here's how on ifixit Adding images to an existing question
by
Power adapter for laptop. The one with the big pin
by
I will send the image to you but is not with me now
by
Add a comment
1 Answer
Hi
Most laptop adaptors are sealed switch-mode power supplies. If it has a damaged connector or cable you could fix it if you can solder. But you will find cheap Chinese knock off adapters on eBay for less than the price of the parts and used genuine adapters at a decent price. You probably aren’t fixing it, but you should ensure the power supply is the issue by checking the voltage across its connector if it does not have a physical problem.
Best regards,
Robin
Add a comment
Add your answer
Sabah Emmanuel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 25
All Time: 221
