ATX Mid Towers have the same general build and parts as other mid size computer towers
Why won’t my pc post after I’ve tried everything?
My PC used to boot up, but now it won’t. All it will do is start, run for 30 seconds, and not post then boot loop and restart. I have to shut it off from the power supply to turn it off as the case button won’t. This happened with my original build, so I replaced the motherboard and cpu, thinking it was my old cpu since I had a bent pin on the last one. Yet, the problem persists. I bought a new motherboard that has argb unlike the old one, and my argb fans will flash when I turn the psu on and then never fully turn on. I’m suspecting RAM or PSU considering it won’t post. The PSU was used and bought from a friend working.
CPU: Ryzen 5 4500
Motherboard: Gigabyte B550 Eagle WIFI6
RAM: OLOY DDR4 RAM 16GB (2x8GB) 3000 MHz CL16 1.35V 288-Pin Desktop Gaming UDIMM (MD4U083016BJDA)
GPU: ASUS GTX 550 Ti(yes yes, I know it’s old, but it should be working as the pc problem persists even when I remove it)
PSU: Thermaltake Smart 650W 80+ Gold Non-modular power supply(it’s an older one)
Case(if needed): Corsair 3500X ARGB
Add a comment
1 Answer
Most Helpful Answer
Hi @phoenixtodoroki
Disconnect the PSU from the motherboard (and any other component) and use the paperclip test to check if all the voltages supplied by the PSU are OK.
If the voltages are OK you may need to connect a system speaker (example only) to the F_Panel (front panel) speaker header pins on the motherboard (see. Item #11 on p.22 of the user manual for location of the header connector on the motherboard and which pins to use) and check what beep codes are heard when the PC is first turned on.
Score 1
1 Comment:
I replaced the power supply with a brand new one, and problem still persists. Fan lights still won’t turn on, unsure of why argb still isn’t working. Hoping I didn’t fry the motherboard with the old power supply, possibly RAM, bought motherboard speaker to check tomorrow.
by
Add a comment
Add your answer
Phoenix Todoroki will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 25
All Time: 120
