The Craftsman Table Saw 137.218072 is a 10-inch blade table saw, capable of rip cuts up to 24 inches and a maximum cut depth of 3 inches at 90 degrees. This page provides repair and additional information about the product, including its 5000 rpm motor, blade guard, riving knife, miter gauge, and more.
Table saw stopped working
This Craftsman saw has not been used in four plus years sitting in a shed. I turned it on with an extension cord and it fired up for about 2 seconds I unplugged extension cord I tried to plug it back in and it will not turn on. I know there's a reset button and I try to push it but it won't work. Any suggestions
Add a comment
1 Answer
Most Helpful Answer
Always best to start with the basics. Here's the manual for your saw; there's a troubleshooting section that I copied below as a place to begin.
Craftsman 137218072 table saw manual
PROBLEM
Saw will not start.
POSSIBLE CAUSES
1. Saw is not plugged in.
2. Fuse blown or circuit breaker tripped.
3. Cord is damaged.
4. Debris in on/off switch
CORRECTIVE ACTION
1. Plug in saw.
2. Replace fuse or reset circuit breaker.
3. Replace power cord.
4. Remove switch from saw and separate in half. Clean any debris accumulated within.
Check their suggestions then come on back and let us know what you find and we'll go from there. Do you have a volt meter and know how to use it?
Score 1
Add a comment
Add your answer
Sean Davis will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 221
