MacBook Pro models with 13" Retina displays manufactured beginning 2012.
Replacing the screen rubber
I have 3 MacBook A1502 13" models 2013/14/15 and all are in desperate need of a new display frame rubber.... do we have to remove the glass to do this or can this be done leaving the glass installed? Contemplating making a guide to do this.....
I seen this video but it looks kinda risky to crack the glass.....
Score 1
Add a comment
1 Answer
Most Helpful Answer
You do not need to remove the glass to replace the display frame rubber (also called the LCD bezel gasket or cushion seal) on the MacBook Pro A1502 models (2013–2015).
Score 2
3 Comments:
Yeah I have seen it done in a couple of videos but it looks real risky that the glass might crack when scraping out the debris.... I will give it a go when the replacements arrive cheers!
by
@livfe how did it go? I were you able to find the replacement gasket online?
by
@ray70829 Yes I managed to install it seemingly OK, quite a tricky task.
by
Add a comment
Add your answer
livfe will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 39
All Time: 255
