Why is my vibration not working
Why is my vibration of Galaxy A31 not working although the setting is on
@frankmhando first you want to check your settings. Make sure it is not set to silent mode and check that vibration is enabled for calls and notifications in the "Sounds and Vibration" menu.
Next you can test your vibration motor by dialing *#0842#
If that does not work either you may just have a bad vibration motor. Since iFixit does not yet have a specific guide to replace this, use the one from here. It is written in Spanish so use a browser that does the translating for you, if needed.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
*#0842# is showing invalid option
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 89
did you check the vibration strength?
by bill
I checked all vibration setting everything is ok but still phone is not vibrating
by Ved
