A midrange Realme phone released in September 17th, 2020. It packs a 6.5" 720p IPS screen with 90Hz refresh rate, Snapdragon 662 and up to 128GB of storage. Not to be confused with its European variant, which is basically a rebrand of Narzo 20.
Why is my screen is ghost touching
How to fix it
Add a comment
Most Helpful Answer
@markdtulod make sure you have removed your screen protector and any case your phone may be in. Then do a restart. If your phone still does the ghost touching, you are having an issue with the display assembly. That is where ghost touching originates; between your digitizer and the screen.
Since iFixit does not yet have a specific guide for this, use something like this video to work on that. Replacement displays are readily available at many online places.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Score 1
Add a comment
If you restart the device, does the issue persist? That's where I would start with the troubleshooting process. You can also try cleaning the screen or updating the device's operating system.
Add a comment
Add your answer
Mark D. Tulod will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 21
All Time: 200
